the strangest thing has been going on. i have tried 2 different linksys routers. and for some reason i keep losing connections with them after a few minutes… and when the customer logs on, the ‘online time’ back at the shop counts down from 10min to zero. instead of counting up. i had to put the router to ‘connect when needed’ but i don’t like doing that.
i upgraded the firmware on both routers but that didnt help.
any suggestions?
Does everything work fine when you bypass the router and plug directly into the pc?
yes and no. it doesn’t lose connection but it still does the ‘countdown’
