It definitely is, though it's sliiiiightly annoying. You can use the L2 firewall feature of the device, through a template like this one;
"template_props": {
"templateName": "ePMP SM Firewall Lite",
"templateDescription": "Just adds the firewall rules",
"device_type": "",
"version": "3.3"
"device_props": {
"l2FirewallEnable": "1",
"l2FirewallTable": [
"l2FirewallEntryName": "WLAN ARP",
"l2FirewallEntryAction": "1",
"l2FirewallEntryInterface": "1",
"l2FirewallEntryEtherType": "2054"
"l2FirewallEntryName": "LAN ARP",
"l2FirewallEntryInterface": "2",
"l2FirewallEntryName": "PPPoE Discovery",
"l2FirewallEntryEtherType": "34915"
"l2FirewallEntryName": "PPPoE Session",
"l2FirewallEntryEtherType": "34916"
"l2FirewallEntryName": "WLAN DST MGMT",
"l2FirewallEntryDstMAC": "${wlan-mac=00:00:00:00:00:00}"
"l2FirewallEntryName": "WLAN SRC MGMT",
"l2FirewallEntrySrcMAC": "${wlan-mac=00:00:00:00:00:00}"
"l2FirewallEntryName": "LAN DST MGMT",
"l2FirewallEntryName": "LAN SRC MGMT",
"l2FirewallEntryName": "Deny all other from WLAN",
"l2FirewallEntryAction": "0",
"l2FirewallEntryName": "Deny all other from LAN",
This lets you fill in the WLAN MAC (used for management traffic) of the SM to allow you to still access the SM's configuration, while passing ARP and PPPoE traffic. I'm not 100% certain the MAC address based rules are actually required, but in our brief testing without them we lost access to the SM's management. You can pull the LAN MAC from cnMaestro, and typically the WLAN MAC is the LAN MAC incremented by 1 (this is different on Elevate SMs)
It would definitely be nice to just have a switch in options to pass only PPPoE traffic and traffic to/from the management address of the SM, or a cnMaestro macro to pull both the LAN/WLAN MAC addresses.
{%esn} is supposed to pull the LAN MAC, but when I dropped that into the firewall rules it threw an error and wouldn't apply; perhaps a formatting issue, as it's not entirely clear what format the macro returns the MAC in, and there's no similar macro for the WLAN MAC (yet?) anyway, so it's of limited use.. I've taken to dynamically generating .json config files with a script that pulls these variables over SNMP, then pushing the config back over SNMP.
The template above is somewhat draconian as it explicitly blocks any/all traffic on all interfaces that isn't ARP, PPPoE, or traffic headed to/from the SM's management MAC address, but we've found this to be useful for reducing spurious broadcast/multicast traffic.
