Hi, I was upgrading an ePMP51 and there was a power failure like 5 to 10 seconds after hiting the upgrade button, now I can’t acces the Web UI nor ping the device at 192.168.0.2
Is there a firmware recovery procedure or what can I do?
Thanks.
Hi, The device’s flash is probably corrupted due to the power outage during an upgrade. Try to factory reset the device using the power cycling procedure found in the User Guide.
I am also facing a same problem. I had tried resetting device using power cycling procedure but didn’t work.
Is there any other procedure for recovering device ?
Bijay,
If you have tried the Power cycling procedure to reset the device, and you have tried the reset button on the device, and you were not able to recover the radio, then you may need to RMA the ePMP radio as you may have corrupted the flash memory.
