My field team just installed a 5.7 MHz SM connecting to an AP supporting 3 other SM units. When inspecting the link quality of the new installation, I noted that the RSSI values is in a red font and the power level is NA.
Has anyone seen this before?
The link test is good and the SM web interface is available (unit must be passing traffic); I do get a power level on the AP side of the link:
RSSI (Avg/Last): 1187/1183 Jitter (Avg/Last): 1/1 Power Level (Avg/Last): -63/-63
Regards,
Tim
Subscriber Modem Stats
Session Status REGISTERED
Registered AP 0a-00-3e-f1-1e-e1
RSSI 1505 (NA)
Jitter 1
Air Delay 130 (approximately 1.21 miles (6370 feet))
AP List
Current entry index: 0
Index: 0 Frequency: 5735.0 MHz ESN: 0a-00-3e-f1-1e-e1
Jitter: 1 RSSI: 1503 Power Level: NA Beacon Count: 35 BRcvW: 1
Type: Multipoint Avail: 1 Age: 0 Lockout: 0 RegFail 0 Range: 6370 feet TxBER: 0 EBcast: 1
Session Count: 1 NoLUIDS: 0 OutOfRange: 0 AuthFail: 0 EncryptFail: 0 Rescan Req: 0
FrameNumber: 785 SectorID: 5 Color Code: 1 BeaconVersion: 1 SectorUserCount: 2
PercentDataDwn: 75 PercentDataUpHi: 0 NumDAckSlots: 3 NumContSlots: 3 NumUAckSlots: 3
Current Results Status
Stats for LUID: 4 Test Duration: 2
Downlink RATE: 4823040 bps
Uplink RATE: 1009920 bps
Downlink Efficiency: 99 Percent
Max Downlink Index: 100
Actual Downlink Index: 99
Expected Frag Count: 18840
Actual Frag Count: 18940
Uplink Efficiency: 100 Percent
Expected Frag Count: 3945
Actual Frag Count: 3945
The red RSSI means your unit hasn’t been calibrated. Browse to:
OLD URL
And enter the MAC addresses of your units. The calibration data will be emailed to you.
Then browse to your Canopy unit’s calibration page using its IP address:
http://169.254.1.1/mac.html (or whatever its IP address has been changed to)
Enter the calibration data, save, and reboot. Now the RSSI will be displayed in black.
