hello,
Does anyone know what power supplies are compatible with the new 450i’s? C050045A002A I believe is the part number. The specs are Input Voltage 48-59 V DC, 802.3at compliant.
Kind regards,
Autumn
hello,
Kind regards,
Autumn
@Autumn wrote:hello,
Kind regards,
Autumn
Hello,
The 450i AP, 450i BHM/BHS should use the:
N000000L034A POWER SUPPLY, 30W, 56V – Gbps support
For the new 900 Mhz product, beware that the SM is based off the 450 platform and should use the:
N000900L001A Gigabit Enet Capable Pwr Supply for ePMP Sync AP (spare) and PMP450
Best,
Cambium Jonathan
Please note that the N000000L034A is brand new and not quite avaialble yet (it should be available starting in January), so for the time being, you can use:
N000065L001B - PTP 650 AC Power Injector, along with a Fig. 8 AC Line cord (N000065L003A, US version).
Matt
Any idea when Matt?
Are they extended temp?
Jeff Broadwick
