Can you have a PPPoE connection on a cnMatrix Switch. We currently hand out Statics and PPPoE is an option that we are looking into.
(2 Internet Connections to a single cnMatrix)
Not possible, use router for that instead L3 switch.
What about NAT? NAT is not supported in cnMatrix. This is because that switch forwards traffic at line rate using hardware, and NAT is not supported in the hardware
The customer doesn’t want a router. Just switches. I know how to program 2 static or dhcp addresses to the switch for redundant internet connection using 1 ethernet port. But for the customer that has a PPPoE they just want a cnMatrix switch to handle there whole Network
