PPPOE is not working on Subscriber Module. I use MikroTik PPPOE server.
Can someone help, thanks?
Dear customer,
We have a number of deployments already with Mikrotik PPPoE server. All are running fine so in your case itr has to be settings issue. Please post us you SM PPPoE settings screenshot as well as simple logical network diagram so we could try to help you.
Regards,
Sebastian
Can you paste mikrotik logs also?
You should enable CHAP auth and disable MS-CHAP.
Cambium is the first vendor for the long time who doesn’t support ms-chap. That’s a bit strange for me!
I also noticeed service name needs to match.
I have problem pppoe please help
se on video
https://drive.google.com/open?id=0B6Gtnw1lCWtyenYxR3pCMk1mRnM
