Pre-shared key (question)
I have a V5000 + v3000 link in testing and works well.
I have activate the Pre-Shared Key and works well.
I i connect another V3000 out of the box (with no configuration on it) it’ connects if the v5000 has the PSK active or i need to disable it, connect it and activate it again?
Thanks!
The suggested method is to login to the new V3K GUI and enable PSK on the device for the first time. Essentially, PSK is not a zero touch.
Otherwise, as you said you can disable PSK at the Config->Network and re-enable it.
