Hi guys, we work with VLANs for each AP or sector, so in “Preferred APs”, in addition to the SSID and encryption setting, we would need to be able to modify the VLAN as well.
Thanks and regards!
do you mean like management/data vlan for SM depending on connected AP?
Hi Andrii, yes, when we change the SM to another tower, we need to change the SSID, encryption and the VLAN ID in Configuration, Networks.
Each node in our Network has your own VLAN ID.
We can’t use this great feature because cannot change the VLAN ID in Preferred AP.
