I've read some old posts on cambium forum indicating Prioritize TCP ACK should be disabled for VoIP customers (TCP ACK's take priority over RTP packets in this case? ) is this still the case?
What is the cambium recommended setting/settings for VoIP customers.
Running VoIP with Prioritize TCP ACK enabled with no ill effects here! On 450 and 100.
EDIT: Mind you all of our customer traffic is encapsulated in PPPoE, so this may play a difference. If your customers are out in the open, yeah, I would not want every single TCP ACK using up bandwidth in the High Priority Channel.
