Canopy Technical Support has released Prizm Patch 6. The patch and can be found on the Canopy website http://motorola.motowi4solutions.com/software/
The following issues are addressed in Patch 6, but please download the Prizm patch 6 Release Notes for more details.
1) Mass Authentication Failures
2) Management IP Not Discovered
3) Database Lockup
4) Prizm Unresponsive After Element Deletion
admin wrote: 3) Database Lockup
Are there any plans to handle the nodemgr_element_attribute table a bit better in future releases? Defaults of varchar(1500) for all those hundreds of fields (plus no indexing) is the biggest hog of resources on our server.
I did the upgrade to patch6 as I did the same way for p5 (according to Release notes) and the Prizm server is unable to start. Reverting back to p5 all is running as expected. Any comments?
I too am experiencing this problem. The error I am receiving when I try and start the server is:
Starting CanopyPrizmServer: execvp: Permission denied
jsutton wrote: I too am experiencing this problem. The error I am receiving when I try and start the server is:
If this is running on a linux OS I would check the permissions of the files. I have no idea what they would need to be, but I would imagine 755 or something similar (we run Prizm on Windows).
I had the same issue. Try this:
chmod 755 /usr/local/Canopy/Prizm/bin/*
The files to start the services aren’t executable. This can be easily verified with:
ls -l /usr/local/Canopy/Prizm/bin/
Charlie
