Prizm problems Server Down
After reinstall step by step I finally can activate the licence files but now I have another error can somebody help me I check all the instructions related to mysql database and I’m stock again
I have this error messange at Prizm Log
07/09/06 19:20:59 WARN SYSTEM DB Initialization Failed: java.sql.SQLException: Invalid authorization specification message from server: "Access denied for user ‘bost_user’@‘ns2.air4access.com’ (using password: YES)"
07/09/06 19:20:59 SEVERE SYSTEM Start Server failed: Failed to startup required Prizm Service: Canopy.Prizm.DatabaseManager
07/09/06 19:20:59 SEVERE SYSTEM EXCEPTION: com.mot.canopy.prizm.core.InvalidConfigurationException: Failed to startup required Prizm Service: Canopy.Prizm.DatabaseManager
com.mot.canopy.prizm.core.Server.loadServices(Server.java:1012)
com.mot.canopy.prizm.core.Server.startup(Server.java:740)
com.mot.canopy.prizm.core.Server.startServer(Server.java:563)
com.mot.canopy.prizm.core.Server.main(Server.java:276)
07/09/06 19:20:59 SEVERE SYSTEM Prizm Server Failed to Start. See above errors.
thanks in advance
acaro2108 wrote:
After reinstall step by step I finally can activate the licence files but now I have another error can somebody help me I check all the instructions related to mysql database and I'm stock again
07/09/06 19:20:59 WARN SYSTEM DB Initialization Failed: java.sql.SQLException: Invalid authorization specification message from server: "Access denied for user 'bost_user'@'ns2.air4access.com' (using password: YES)"
I was once facing the same problem with you. ;) Please make sure that you have 'grant access' for user 'bost_user' in hostname 'ns2.air4access', with the appropriate database. It's only the matter of user permission in order to access the database.
Hope it'd help.
hello bekicotrasta
yes you was rigth thanks for the advise
this problem is fix but other appear this time i got the follow error at my log maybe you know what can I do to fix it
again thank for you value answers
SEVERE SYSTEM Start Server failed: Failed to startup required Prizm Service: Canopy.Prizm.BAMManager
07/11/06 19:21:21 SEVERE SYSTEM EXCEPTION: com.mot.canopy.prizm.core.InvalidConfigurationException: Failed to startup required Prizm Service: Canopy.Prizm.BAMManager
hello again bekicotrasta
I finally found all my problems
( the user name and password for bam was not changed)
thanks for all your help
Nice job dude!
:wink:
