Hi There,
I thought I’ll just try my luck on the forum before I follow the Moto Tech support and reinstall the server from scratch. They seem to be at a loss on why my server is behaving the way it does.
My Prizm start giving some problems a few days ago where the BAM part of the server just won’t startup. The error message in the log file complains that BAM can’t make a connection to the ODBC driver but I’m almost a 100% that ODBC is functioning correctly since I can establish a manual connection using the same DSN that Prizm is suppose to use.
The other strange thing is that BAM(engind) sometimes come alive all on it’s own for no apparent reason at a random interval of time.
I’ve also double checked my confic files and can say with much certainty tat they’re correct. Have any one else experience something similar then this and is there a quick fix or am I left to follow the advise dispensed by the Moto tech guru’s?
Info 03/01/2007 8:45:19 File: odbc.cpp Line: 150 Message: constructor of Database called with keep alive: 1
Info 03/01/2007 8:45:19 File: odbc.cpp Line: 78 Message: ODBC: Open connection
Info 03/01/2007 8:45:19 File: main.cpp Line: 101 Message: Main connection to database established
Severe 03/01/2007 8:45:19 File: odbc.cpp Line: 118 Message: Unable to make connection with ODBC driver
Severe 03/01/2007 8:45:19 File: main.cpp Line: 414 Message: Unable to run engined: Unable to connect
