Hi all,
I have a PTP600 network (6 interconnected links) that i need to manage with Prizm.
I want to be able to monitor AND configure the units from a single Prizm server. So far I know this is not possible yet for PTP units.
Is there a modified version of Prizm or other software out there that do this for me?
With Prizm 3.1 you should be able to monitor the units just fine.
I would still plan on updating them via the software upload directly on the unit.
And the templates you can use on them are limited so whatever you are doing to manage the units you will probably have to stick to that.
