Problem e400
Hello! I created a wifi network with:
1 router Mikrotik
8 access point E400
 All right, there is only one problem the customer fails to use AppleTV.
If I connect AppleTV to router it works but if I connect AppleTV to access point no.
Can someone help me?
thank you.
Massimo
1 router Mikrotik
8 access point E400
thank you.
Massimo
Is the Apple TV not connecting to the access point, or does it connect ok, but you are not able to play any video?
What do the logs on the AP (in the AP GUI under troubleshooting there is an option to view debug logs) say about the connection from the AppleTV to the AP?
check this out - it's not actually the E400.
http://www.appledystopia.com/how-to/apple-tv-4-fix-wifi-problems-page-1/
the tv apple connects without problems to the network, but it is not possible to upload movies or even YouTube
