i have downloaded the file to install prizm for windows but when i run the file the setup don’t start.
Can you help me?
Best regards
Is the version of windows you are using supported? Did you get a license?
Yes…
The problem is the md5 checksum…
it is different on my computer when i download the file
I would try downloading it again (possibally on another machine).
I guess it is possible that Moto posted the wrong MD5 or a corrupted file. But I would think it much more likely that your download was jumbled somehow.
