Hello, My name's Misael. I'm trying to install on centos 6.5 the last version of CNS Server 1.3.1 and I really have my /etc/hosts as have to be, installed dos2unix, and when execute the script .run become an error, like this:
########################################Error copying file from /opt/cnsserver/httpd.conf to /opt/cnsserver/stack/apache2/conf/httpd.conf
:Destination not writable
Abort, Retry, Ignore ? [A/r/i]
If i ignore this, continues with others issues..
Warning: Problem running post-install step. Installation may not complete
correctly
Error writing file /opt/cnsserver/stack/postgresql/data/pg_hba.conf
Press [Enter] to continue :
correctly
Error running /opt/cnsserver/scripts/cnss_folder_permission.sh : chmod: no se
puede acceder a «../stack/php»: No existe el fichero o el directorio
I tried to install differents versions, but, its impossible, only 2.0 left me install without errors, but unfortunately not finish the script, its stay freeze on 100% and doesn´t show anything.
can you help me please?
I'm using centos 6.5
Thank You
