Hi this is my first post on this forum.
I´m a it staff on a little Wisp in Spain.
I have a problem to acces SM after registration.
When sm is not registered, i can acces via web,telnet etc… in nat sm or sm without nat .
When the sm is registered, i can´t acces locally to the sm.
Via ap i can acces to the regiastered sm.
I DON´T UNDRESTAND WHAT´S HAPPEN!!
1 month ago no problems with this.
For hep us, we have PRizm server 3.1 , sm firmware 9.0
Thanks in advance!
Are you using VLANs?
yes, i have vlan
thanks!
Change the access from local to public?
public or local no works
thanks!
Are you receiving an IP from a DHCP on the computer you are using?
You need to ahve a IP and Subnet that match the SMs private ip/subnet as well.
pc : 169.254.1.2/16
sm : default ip
no works
maybe hard reset it, it may correct the problem i hope
If you’re using VLAN’s then you can only access the SM on that specific management vlan when it’s registered with your AP. Pickup a cheap switch that can deal with Vlan’s or get a nic card that will use 802.1q
