All settings as far as logins are correct. This is the error I get:
01/13/11 15:16:32 INFO CMM_31_BUILDOFFICIAL.pkg3 loaded.
01/13/11 15:16:32 INFO Starting Update Process …
01/13/11 15:16:32 INFO Using Active FTP for File Transfer
01/13/11 15:16:32 INFO Queue NE:10.10.10.13 for updating
01/13/11 15:16:33 INFO Host: 10.10.10.13;ESN: 0A003EE02331;Message: Checking Network Element Status (SITE= Ketchum Tower CMM)
01/13/11 15:16:33 INFO Host: 10.10.10.13;ESN: 0A003EE02331;Message: Current = CANOPY CMM 2.2 Build 2 Feb 23 2006 16:45:22, , 5 (SITE= Ketchum Tower CMM)
01/13/11 15:16:33 INFO Host: 10.10.10.13;ESN: 0A003EE02331;Message: Using Package D:'Brad’Canopy’Canopy Software’CMM_31_BUILDOFFICIAL.pkg3 (SITE= Ketchum Tower CMM)
01/13/11 15:16:33 INFO Host: 10.10.10.13;ESN: 0A003EE02331;Message: Transferring Files: boot.bin (SITE= Ketchum Tower CMM)
01/13/11 15:21:33 WARN Host: 10.10.10.13;ESN: 0A003EE02331;Message: Error Transferring Files: Error: could not send/close local file.Connection timed out. (SITE= Ketchum Tower CMM)
01/13/11 15:21:33 INFO Node: 10.10.10.13 Update Completed.
01/13/11 15:21:33 INFO Refreshing NE at:10.10.10.13
01/13/11 15:21:41 INFO Updating Selected Network Elements process has completed.
Make sure you are not running this from a PC that is behind a firewall or has a software firewall enabled.
Yes, first hint is that “01/13/11 15:16:32 INFO Using Active FTP for File Transfer”. Unlike Passive FTP, Active FTP requires the server to initiate a connection back to the client. This will not work with a firewall or anything running NAT.
i had the same issue…
what is did was to remove the snmp string and snmp ip …save and reboot and it worked…i spoke to support and they where no help
Tried using passive FTP and SNMP solution to no avail. Connected up directly to the CMM and successfully upgraded. Thanks for the input.
Brad
