Hi, we have a problem with two device Cambium. It's possibile that Board Temperature : 103 C / 217 F is a "fake" message and the problem was another?
1) AP Cambium rebooted for Hardware Watchdog Reset
5.4GHz MIMO OFDM - Access Point - 0a-00-3e-bb-XX-XX
Software Version : CANOPY 14.1.2 AP-AES
Software Boot Version : CANOPYBOOT 1.0
FPGA Version : 050516
PLD Version : 1
Frequency Band : 5.4GHz
Hardware Platform : 13
Hardware Minor Revision : 0
Device Type : CANOPY
Problem:
******System Startup******
System Reset Exception -- Hardware Watchdog Reset
Board Type : P13
Device Setting : 5.4GHz MIMO OFDM - Access Point - 0a-00-3e-bb-XX-XX
No valid accounts configured. Using default user account - 5510.0 MHz - 20.0 MHz - 1/16 - CC 4 - 2.5 ms - Other Regulatory/Other
FPGA Features : AES, Sched, US/ETSI;
09/20/2016 : 07:57:21 UTC : :Time Set
09/20/2016 : 07:57:44 UTC : :Board Temperature : 103 C / 217 F
09/20/2016 : 07:57:46 UTC : Acquired sync pulse from Power Port
Actual in HomePage:
Temperature : 32 °C / 90 °F
2) SM Cambium
Software Version : CANOPY 14.2.1 (Build 16) SM-AES
FPGA Version : 080216
PLD Version : 1
System Reset Exception -- Reset due to FatalError
Software Version : CANOPY 14.1.2 (Build 17) SM-AES
Board Type : P13
Device Setting : 4.9/5.9GHz MIMO OFDM - Subscriber Module - 0a-00-3e-bb-XX-XX
FPGA Features : AES, Sched;
09/06/2016 : 07:13:23 UTC : :Board Temperature : 103 C / 217 F
09/11/2016 : 02:25:14 UTC : :Time Set
09/11/2016 : 02:33:44 UTC : :Time Set
09/18/2016 : 10:38:45 UTC : :Invalid ACK discarded, VC: 28 0a003ebb37fd
09/20/2016 : 07:28:54 UTC : :Web user; user=none; Reboot from Webpage; -> today my manual reboot after seen 103 °C in event log but normal in Homepage
09/20/2016 : 07:29:00 UTC : :Forced reset;
09/20/2016 : 07:29:10 UTC :
System Reset Exception -- User Initiated Reset
Board Type : P13
09/20/2016 : 07:29:33 UTC : :Board Temperature : 103 C / 217 F
09/20/2016 : 07:41:44 UTC : :Web user; user=none; Reboot from Webpage;
09/20/2016 : 07:41:49 UTC : :Forced reset;
01/01/2011 : 00:00:10 UTC : :01/01/2011 : 00:00:00 UTC : :Time Set
Software Version : CANOPY 14.2.1 (Build 16) SM-AES -> upgrade
Board Type : P13
01/01/2011 : 00:00:34 UTC : :Board Temperature: 32 C / 89 F
09/20/2016 : 07:45:12 UTC : :Time Set
Actual in HomePage:
Temperature : 34 °C / 93 °F
