If it’s showing “under current” it means the GPS antenna likely isn’t powering up. If you’ve already tried a new cable to the antenna, try a new antenna. Is thy doesn’t work, then the problem is probably in the CMM. I’ve never opened up a CMM4 to see if the GPS is replaceable like in the CMM3.
