I recently have a problem with CMMMICRO.
this are my status pages,
Device type
CMM xx-xx-xx-xx-xx-xx
PLD Version
5
Software Version
CANOPY CMM 2.0.8 Nov 14 2003 14:11:10
System Time
02:16:59pm Sat Nov 05 2005
Up Time
00:47:59
Satellites Visible
8
Satellites Tracked
8
Latitude
N11 12.5520
Longitude
W74 12.6330
Height
383 meters
Tracking Mode
3D Fix
SYNC Pulse Status
SYNC OK
the right leds are green ->satellites visibilitys is ok.
The right leds:
PWR GREEN
DFLT: OFF
SYNC: GREEN
RDY GREEN BLINKING.
The leds status are perfect,
The AP’s are setted to :
Sync to Received Signal (Power Port)
AP’s are advantadge 5750
Firmware 7.2.9.
The are only four ap’s on this cluster. only one is receiving sync.
I tried this:
- reset to factory defaults on AP and make a new setup, but is not working yet.
- Make a power cycle on GPS.
- replaced the cables.
- verify the Protective Earth conectivity and voltages, temperature is ok.
- verify on others ports on GPS.
Only on AP is working.
i will make a firmware update on CMM.
what do you think? i need help.
regards,
Aquiles.
I take it the AP’ are powering up.
Have you tried chaning the ports you are plugged into in the CMM.
Take an AP that is not working and use the CMM port from the AP that is working.
On the AP that is not working, change the setting from get timing from power port to generate its own sync.
Did the AP’s ever work ?
Yes i tried.
I did but dont receive sync
>On the AP that is not working, change the setting from get timing from power >port to generate its own sync.
I dont understand why i need to try generate it’s own sync. but yes the AP’s can generate its own sync and the SM get associated, but i have a four AP cluster and i need to sync the four AP`s.
Yes the AP was working using CMM2 trough RJ-11 Port. acctually using CMM2 the AP get sync. but with CMMmicro dont recive the sync.
using the same CMMMicro and the timing pulse J8 (CMMMicro has one port with RJ-11) One AP more get sync.
i have only one AP with sync trought POwer POrt and One trought J8 Timing pulse connector.
