Hello, I elevate same UBNTs with the elevator, doing it one by one.
The CPE UBNT ELEVATE connect to the AP but internally in the LAN do not assign dhcp inside so the clients are running out of internet and I have to reload the UBNT firm so they can navigate.
Someone with the same problem?
What solution can I have?
Thank you
Do you see the problem using the below Device Elevator?
