hi
i have a problem connecting my prtg monitor with cambium450 for monitor signal.
have someone got this problem?
thanks
hi
thanks
Hello elia,
Which part of setting up the sensor are you having issue with. Creating the custom sensor or which OID to use?
Also what device are you trying to get power Levels for SM or a Backhaul
There should be no problem. Try OID 1.3.6.1.4.1.161.19.3.2.2.61.0 Type Gauge (signed integer).
doesn't work.
I would like to see these values:
RECEIVE POWER: -68.9 dBm (for example)
ETHERNET INTERFACE: 100bASE-tx fULL DUPLEX
thank you
