Problem with PTP54300
We have problem with PTP54300. Link suddenly stoped to work. Close check showed, that problem is with one SMD component. Hi has code 2A. What it is?
TNX.
BR, Tomi
Hi Tomi,
These devices are intended to protect the Ethernet transceiver against damage due to a lightning surge. We've changed them in the past. You might like to contact Customer Support to raise a ticket and return the unit for repair.
Thanks, Mark
