Actualmente tengo problemas con 3 ap Epmp2000 que estan en la misma estacion. Estas se deben rebootear 2 a 3 veces en el dia ya que se pierde comunicacion con los cpe. Estas celdas cuentan 30 cpe y elevan su cpu sobre el 70% pasando un aproximado de 50MB. Actualmente estan sincronizadas con gps. (Puede ser un tema de que se esten interfiriendo aunque las frecuencias utilizadas tengas una separacion de 100 MHZ)?
Buen dia. Tengo el mismo problema. Pudiste resolver?
Hi Guys. In order for anyone to help, they are going to need to know more information. Such as...
What Firmware is running on AP and on SM's?
What kind of SM's are they - Force200's, or Force190's, or are they Force300's in compatability modes?
What country are you in?
Are the SM's bridged or NAT'd?
If I was you, I would supply a screen shot of the AP's configuration screens - there are many, many settings which can affect things. The more info you can provide, the better chance someone from the community can help out. :)
