lcalderon
(lcalderon)
November 2, 2016, 2:50pm
#1
I try to connect to cnMaestro, I get this error:
Nov 2 14:47:46 Sant Carles DEVICE-AGENT[21045]: get_from_cnsrouter: Received: 404 Not Found ret=1
Nov 2 14:47:46 Sant Carles DEVICE-AGENT[21045]: Unable to load response JSON ,error on line 1: '[' or '{' expected near 'Not'
Nov 2 14:47:46 Sant Carles DEVICE-AGENT[21045]: Unable to discover cnMaestro URL (re-discover in 78 seconds)
I can do a ping from the CLI but sims the URL is not discovered.
Fedor
(Fedor)
November 2, 2016, 2:59pm
#2
Please check whether this issue is the same with issue you have faced:
http://community.cambiumnetworks.com/t5/cnMaestro/ePMP-DNS-Issues/m-p/61346#M1033
Thank you.
Fedor
(Fedor)
November 3, 2016, 8:16am
#3
Thank you for sending me configuration file from your device.
I see you are using cnMaestro Cloud solution.
So issue I've redirect you to is not relevant for your case.
It looks like there is some maintenance works on network or Cloud.
Did you try to connect your device first time or not?
Thank you.
nwtowers
(nwtowers )
November 10, 2016, 8:17pm
#4
I'm seeing this same issue trying to adopt PMP450i devices to cloud.cambiumnetworks.com
11/10/2016 : 12:03:39 PST : : Unable to load response JSON ,error on line 1: '[' or '{' expected near '<' 11/10/2016 : 12:03:39 PST : : Unable to discover cnMaestro URL (re-discover in 347 seconds) 11/10/2016 : 12:03:39 PST : : Attempting (re)connection in 5 minutes 11/10/2016 : 12:09:28 PST : : Unable to load response JSON ,error on line 1: '[' or '{' expected near '<' 11/10/2016 : 12:09:28 PST : : Unable to discover cnMaestro URL (re-discover in 359 seconds) 11/10/2016 : 12:09:28 PST : : Attempting (re)connection in 5 minutes 11/10/2016 : 12:15:29 PST : : Unable to load response JSON ,error on line 1: '[' or '{' expected near '<' 11/10/2016 : 12:15:29 PST : : Unable to discover cnMaestro URL (re-discover in 335 seconds) 11/10/2016 : 12:15:29 PST : : Attempting (re)connection in 5 minutes
Fedor
(Fedor)
November 11, 2016, 1:25pm
#5
Thank you for your feedback.
Engineers are already working on this issue.
Could you please confirm you are trying to connect to cnMaestro:
And you see cnMaestro Version 1.2.0-r2 on Web-page.
Thank you.
