Hi, i have a problem with my Canopy BH20-DES, wich losses around 40% of packets sent randomly.
I have another link betwewn otrher 2 Canopy, that works great and is connected in the same tower.
I've checked the statistics, signal-power-level and noise and all is normal.
I've tried a firmware upgrade (now it's 13.1.3, the newest), change both poe adapters, change frecuencys with the good link and change between the APs sites roles (master/slave) and saw nothing improve.
Aditionally, i paste the slave stats 2 minutes after manually restart:
Session Status : |
REGISTERED VC 18 Rate 2X/1X VC 255 Rate 2X/1X
Session Uptime : | 00:01:59 |
Registered Backhaul : |
0a-00-3e-XX-XX-XX No Site Name
Channel Frequency : | 5865 MHz |
Power Level : | Actual: -42 dBm Min: -42 dBm Max: -40 dBm
Jitter (Interference Level) : | Actual: 3 Min: 1 Max: 5
Air Delay : |
269 bits, approximately 2.503 miles (13221 feet)
Any ideas?
