Hi forum users.
We have recently noticed the PTP450 solution.
We believe the connectorized version may be suitable to a large variety of our network’s needs.
A few technical questions.
1. Is the PTP450 based on a Atheros chipset with standard 52 subcarriers aka EPMP 1000?
2. What makes this product better than the 1000 range (Better / faster DSP’s etc)
3. Is the PTP450 a direct derivative of the PMP 450 series hardware / DSP / asic wise?
We value the PTP600 /PTP 500 series’ resilience and performance in high interference deployments.
How close should the PTP450 series get to PTP500-full license in performance levels in real world situations.
Thank you for your time.
PTP-450 is a derivative of the PMP-450 platform. You can expect the same differences as between the PTP-100 and PMP-100 FSK gear.
PMP-450 is not WiFi-based. Everything that’s different between the ePMP series and PMP-450 also applies here.
Thank you salad.
Is there any source of information detailing differences between ePMP1000 and PMP-450?
Thank you.
No single document I’m aware of, I’d suggest starting with the product pages and reading the marketing info for each platform.
http://www.cambiumnetworks.com/products/epmp
http://www.cambiumnetworks.com/products/pmp/pmp-450
PTP 450 is coming very soon.
You may get the spec-sheets here: http://www.cambiumnetworks.com/products/ptp/ptp450
