What possibly can be an effect to the performance of the link when installed or co-located into an FM station tower.
As have observed graphical install status color which turns red (even at high value of 35) disconnecting the link in a cycle.
What’s the best do’s for this kind of setup?
Hi Gerry,
Real sorry no one has got back to you on this. I’ll get someone on it first thing Monday if it is still a problem. If you need more urgent help please contact our support team.
http://www.cambiumnetworks.com/support/contact-support
Andy
Hi Andy,
at least we must have some info regarding this kind of installations. related issue or similar issues would be an ODU colocated in a TV tower/station.
Probably this will help - as the power goes up, increase the separation using a log function (S= 11+ 10*log (P/1KW)) where S = separation in meters and P = transmit power in KW. This translates to the following distances:
Transmit Power |
Distance |
100W |
1 meter |
1KW |
11 meters |
10KW |
21 meters |
50KW |
28 meters |
100KW |
31 meters |
Comments pls.
