16179 00:11:29 Jan 1 00:00:00 NTP Notice configuration; System Clock; Web user; was=07-Feb-2106 02:28:16; now=05-Feb-2019 02:59:16;
16178 00:22:47 Jan 1 00:00:00 Security Info event; auth_login; Web user=SystemAdministrator; from=192.168.1.15; port=80; connection=HTTP; authentication=local;
16177 00:26:36 Jan 1 00:00:00 Local 5 Warning status; Data Bridging Status; was=Disabled; now=Enabled;
16176 00:26:36 Jan 1 00:00:00 Local 5 Warning status; Wireless Link Status; was=Down; now=Up;
16175 00:30:41 Jan 1 00:00:00 Kernel Warning event; cold_start; PTP wireless bridge has reinitialized, reason=Registration Timeout;
16174 00:35:48 Jan 1 00:00:00 Kernel Warning event; sys_reboot; System Reboot, reason=Registration Timeout;
16173 00:50:41 Jan 1 00:00:00 Kernel Warning event; cold_start; PTP wireless bridge has reinitialized, reason=Registration Timeout;
16172 00:55:48 Jan 1 00:00:00 Kernel Warning event; sys_reboot; System Reboot, reason=Registration Timeout;
16171 01:10:41 Jan 1 00:00:00 Kernel Warning event; cold_start; PTP wireless bridge has reinitialized, reason=Registration Timeout;
This is normal... when the radios cannot establish a link after 5 minutes it will reboot and try again.
Que tal Alfredo.
Si puedes compartir las pantallas de Status e Instalation donde figure la configuración de cada uno de los dos equipos podría ayudarte de mejor manera. Es probable que los equipos no puedan enlazar y estén reiniciando constantemente.
Hi Alfredo.
If you can share the Status and Installation screens where the configuration of each of the two devices appears, it could help you better. It is likely that devices can not register and are constantly restarting.
Is it possible to disable this feature?
It is not normal, use version 01-41 link stable work and device not rebooting 600 days after upgrade on version 01-47 every day radio reboot
