PTP 850C Management Ethernet Port
We are having troubles maintaining a stable ethernet connection on P6 of the 850C. We use this port for programming, and usually it stays stable, but recently we have tried multiple radios with multiple ethernet cables, power supplies, laptops, and they are all dropping this ethernet connection. The power is staying consistent at 52VDC.
UPDATE:
The radio does not move on from a solid red light, which per the user guide, means initializing mode. It has been plugged in for 30 minutes and has not moved on from a solid red light
I think you should contact Cambium customer support for help.
Thanks.
