We are experiencing connectivity issues with our PTP700 Series Units dropping connection.
Usually, a power cycle will re-engage the link but this is servicing critical communications that cannot afford to be randomly dropped.
MAC address sanitized.
See logs:
++++++MASTER LOG+++++++
|2291|15:37:04|Jan 1 00:00:00|Local 5|Warning|status; Data Bridging Status; Remote MAC=xx:xx:xx:xx:xx:xx=; was=Disabled; now=Enabled;|
|2290|15:37:05|Jan 1 00:00:00|Local 5|Warning|status; Wireless Link Status; Remote MAC=xx:xx:xx:xx:xx:xx; was=Down; now=Up;|
|2289|15:37:05|Jan 1 00:00:00|Security|Info|event; EAP TLS Authentication; Remote MAC=xx:xx:xx:xx:xx:xx; Authentication success; Cipher=AES 256-bit TLS PSK;|
|2288|15:39:32|Jan 1 00:00:00|Kernel|Warning|event; cold_start; The unit’s wireless bridge has reinitialized, reason=Registration Timeout;|
|2287|15:47:41|Oct 3 09:17:55|Kernel|Warning|event; sys_reboot; System Reboot, reason=Registration Timeout;|
|2286|15:52:42|Oct 3 09:12:54|Local 5|Warning|status; Wireless Link Status; Remote MAC=xx:xx:xx:xx:xx:xx; was=Up; now=Down;|
|2285|15:52:42|Oct 3 09:12:54|Local 5|Warning|status; Data Bridging Status; Remote MAC=xx:xx:xx:xx:xx:xx=; was=Enabled; now=Disabled;|
++++++SLAVE LOG+++++++
|2078|15:29:00|Jan 1 00:00:00|Local 5|Warning|status; Data Bridging Status; Remote MAC=xx:xx:xx:xx:xx:xx=; was=Disabled; now=Enabled;|
|2077|15:29:01|Jan 1 00:00:00|Local 5|Warning|status; Wireless Link Status; Remote MAC=xx:xx:xx:xx:xx:xx; was=Down; now=Up;|
|2076|15:29:01|Jan 1 00:00:00|Security|Info|event; EAP TLS Authentication; Remote MAC=xx:xx:xx:xx:xx:xx; Authentication success; Cipher=AES 256-bit TLS PSK;|
|2075|15:29:26|Jan 1 00:00:00|Kernel|Warning|event; cold_start; The unit’s wireless bridge has reinitialized, reason=Long Power Cycle;|
