In the Power Section of the PTP450 user configuration software, it shows the transmitter power output as 25dBm, andthen beside it there is a field that says "(22 dBm A/ 22dBm B)".
If I change the transmitter power output to 19dBm, that field says " (16 dBm A/ 16dBm B)"; there is always a 3 dB reduction from the TPO.
What does this mean?
- PTP450 Power Question.JPG (23.3 KB)
