I see from the manual that the ODU accepts power using 802.3at rating. Do this mean I can use any PSU or POE switches that can provide 802.3at power rating as well?
BR,
Gerry
BR,
Gerry
Hi Gerry,
Yes, you should able to use any PoE switch which supports 802.3 at. However, we cannot gurantee the quality of the PoE switch which can impact the radio performance
Sagar
