PTP550 Integrated Antenna Patter
Is there any available data pertaining to the PTP550 Integrated panel antenna pattern. Is this similar to the PTP650 flat panel antenna as well?
BR,
Gerry
Hi Gerry,
Attached is the antenna spec sheet for PTP550.
Thanks Brian!
Hi Brian,
Do PTP550 and PTP670 share the same antenna type and specification?
BR,
Gerry
Hi Gerry,
550 and 670 share very similar antenna spec and antenna pattern such as antenna gain, 3 db beamwidth.
Sagar
