The PTP550 with versions 4.1.2 and higher do not allow to configure Transmit Power greater than 25 dBm in any band. The region code used is Other, 20MHz and channel bonding disabled.
The version 4.1.1 allows Tx power 29dBm.
Will this limitation be removed on next versions?
