BNC port for voltage alignment reference should have been retained, as this is more easy to use than the buzzer itself.
HI Gerry,
thanks for the feedback. We are looking at some alternatives to continue to improve the alignment process with PTP links. In addition to the tones have you also tried the on-screen alignment in the GUI?
What do you think of the ability to do alignment with a smartphone interface?
Regards,
Bruce
Hi Bruce,
Yes, we are using those features as well.
However alignment process using voltage measurements came to be more efficient in many ways and in different situations.
So we are hoping it could be introduce as well with PTP650 and other incoming new models.
Many thanks.
