PTP650 RELAY (30.4km & 22.2km) - w/ HOG power system (2016 Last Project)
Where is this installation located?
Hi
I am keen to know the  configuration used for such a long link. Would appreciate if you can share more info.
cheers
Hi Ray,
We have this installation located in the province of Benguet. Just at the side and slope of 9th highest mountain (Mt. Timbac)  in the Philippines.
Regards,
Gerry
Hi  Avinesh,
Attach are the actual link status obtained. This is the actual configuration:
 This is my link planner predicted outputs at NIB.
Radio: PTP650 Lite
30.2km - running at 40MHz, nLOS
22.2km - runnning at 30MHz, LOS
Hi Gerry
Thank you for sharing the information. Are you using Integrated antennas?
Yes it is.. those are the actual pictures of the installed devices..
