PTP650L compatible with PTP650
Do PTP650L End can work with PTP650 ?
if yes, whats is the compatibility firmware ?
You should be able to create a link between PTP 650 and PTP 650L. There is no special compatibilitiy firmware but (as usual for PTP 650) you will need the same version at each end. I suggest using the latest version.
PTP650L was originally sold with a 10 MHz bandwidth limit. If you have one of these units, you can regenerate the License Key to get a free upgrade to 30 MHz. You will need to select bandwidth of 5 to 30 MHz on the PTP 650. Please get back to us if you have any problems.
