PTP800 - Custom made Poller for configuration only
Dear Cambium Engineer/s,
Is it possible for Cambium to provide the customized poller config which can be used to poll only the configuration from this MIB instead of polling everything.
As part of Blueprint, we would like Solarwinds health monitoring application to poll the config once every month and compare against the existing. As we noticed that the config file of PTP800 is a .cfg file and can not be open with Notepad or Wordpad, the only option for us to achieve our requirement is to make a custom poller which can poll the config from the MIB file.
If you can assist or provide us the custom poller file (xml preferred), so that we can use that file for Solarwinds to do the required work.
Please feel free to contact me if you require further info.
Regards,
Dip
