PTP820 Remote Mount Configuration
Direct mount is  the most simple way for PTP820 installation. But sometimes when we may not be able to due to different reasons like:
1. Re-use an existing antenna which doesn't have PTP820 interface
2. PTP820 direct mount antenna only covers from 1ft to 6ft. If a 8 or 10 foot antena is needed, these anntena has no PTP820 direct mount interface
The good news is PTP820 also support remote mount configuration, for both PTP820S, PTP820C and PTP820G RFU. The latest linkplaner tool provide this options and customer can choose for remote mount, which will provide a complete BOM for such configuration.
And often, people like to know how flange match each otehr in such configuration, i create a table bellow which can help address this type of questions.
Frequency (GHz) Waveguide Standard Radio interface Remount Mount
Adaptor Flange
Flex Twist Flange Antenna Flange
6 WR137 Proprietory Propretory <-> UDR70 PDR70<->PDR70 UDR70
7/8 WR112 Proprietory Propretory <-> UBR84 PBR84<->PBR84 UBR84
10/11 WR90 Proprietory Propretory <-> UBR100 PBR100<->PBR100 UBR100
13 WR75 Proprietory Propretory <-> UBR120 PBR120<->PBR120 UBR120
15 WR62 PBR140 N/A PBR140-PBR140 UBR140
18-26 WR42 PBR220 N/A PBR220<->PBR220 UBR220
28-38 WR28 PBR320 N/A PBR320<->PBR320 UBR320
42 WR22 UG383/U N/A UG383/U <->UG383/U UG383/U
For 6-13 GHz, we do need a remote mount adpator for any remote mount configuration. For 15GHz and above,  radio has standard flange and customer can connect the  radio with antenna with the right flexible waveguide.
Allen
