Ali_Shoaee
(Ali Shoaee)
February 6, 2016, 4:30am
#1
Dear ,
Please provide RSL (receive signal level) Chart for typical PTP 820S microwave link base on voltage decreases, signal strength increases .
Please Share with us Technical Manual / Video for RSL Test by Voltmeter that show how Voltage change base on Signal strength ....
What is RSL Voltage to Verify the Link Quality voltage ?
Best Regards,
Ali
Have you downloaded our free program, LINKPlanner?
If you use LINKPlanner to create and configure a link, you can generate an installation report that provides the expected RSL (dBm) and voltage at the BNC connector.
The lower the voltage, the better.
Please see this forum post for specific RSL voltage conversion: http://community.cambiumnetworks.com/t5/PTP-820-Licensed-Microwave/How-do-I-use-the-PTP-820-BNC-connector-RSL-interface-during/m-p/40337#M78
I hope this helps!
Dave
