Hi all,
Would anyone be able to share a raw syslog file with me? I have 2 links on order and wish to start prepping Syslog and RADIUS servers for deployment.
Hey @Khan_McDonald, welcome to the Cambium forums. I hope this helps you out:
[20250723221520 1.2.3.9] (Jul 23 22:15:20 1.2.3.9) mw:: 675| 23-07-2025,22:15:20| WEB| 4.3.2.1| admin| SUCCESS: UPDATE remote-syslog-server-configuration-table[0] : remote-syslog-cfg-admin-status=enable
[20250723221640 1.2.3.9] (Jul 23 22:16:40 1.2.3.9) mw:: 1065| admin| WEB| 4.3.2.1| 23-07-2025,22:16:40| Added SNMP V3 user username = justatestuser
[20250723221640 1.2.3.9] (Jul 23 22:16:40 1.2.3.9) mw:: 676| 23-07-2025,22:16:40| WEB| 4.3.2.1| admin| SUCCESS: ADD snmp-v3-authentication-table[2] : snmp-v3-authentication-username=justatestuser | snmp-v3-authentication-password=******** | snmp-v3-authentication-access-mode=ROUser
[20250723221640 1.2.3.9] (Jul 23 22:16:40 1.2.3.9) mw:: 1066| root| INTERNAL| 0.0.0.0| 23-07-2025,22:16:40| set snmp-s-operation-status = up succeeded
[20250723221640 1.2.3.9] (Jul 23 22:16:40 1.2.3.9) mw:: 1067| root| INTERNAL| 0.0.0.0| 23-07-2025,22:16:40| set snmp-s-operation-status = up succeeded
[20250723221641 1.2.3.9] (Jul 23 22:16:41 1.2.3.9) mw:: 1068| root| INTERNAL| 0.0.0.0| 23-07-2025,22:16:40| set snmp-s-operation-status = down succeeded
[20250723221641 1.2.3.9] (Jul 23 22:16:41 1.2.3.9) mw:: 1069| root| INTERNAL| 0.0.0.0| 23-07-2025,22:16:41| set snmp-s-operation-status = down succeeded
[20250723221641 1.2.3.9] (Jul 23 22:16:41 1.2.3.9) mw:: 1070| root| INTERNAL| 0.0.0.0| 23-07-2025,22:16:41| set snmp-s-operation-status = up succeeded
[20250723221645 1.2.3.9] (Jul 23 22:16:45 1.2.3.9) mw:: 1071| admin| WEB| 4.3.2.1| 23-07-2025,22:16:45| Deleted SNMP V3 user username = justatestuser
[20250723221645 1.2.3.9] (Jul 23 22:16:45 1.2.3.9) mw:: 1072| admin| WEB| 4.3.2.1| 23-07-2025,22:16:45| delete table snmp-v3-authentication-table: succeeded
[20250723221645 1.2.3.9] (Jul 23 22:16:45 1.2.3.9) mw:: 1073| root| INTERNAL| 0.0.0.0| 23-07-2025,22:16:45| set snmp-s-operation-status = up succeeded
[20250723221645 1.2.3.9] (Jul 23 22:16:45 1.2.3.9) mw:: 677| 23-07-2025,22:16:45| WEB| 4.3.2.1| admin| SUCCESS: DELETE snmp-v3-authentication-table[2] : snmp-v3-authentication-username=justatestuser | snmp-v3-authentication-password=******** | snmp-v3-authentication-security-mode=AuthPriv | snmp-v3-authentication-encryption-mode=DES | snmp-v3-authentication-auth-algorithm=MD5 | snmp-v3-authentication-access-mode=ROUser
[20250723221646 1.2.3.9] (Jul 23 22:16:46 1.2.3.9) mw:: 1074| root| INTERNAL| 0.0.0.0| 23-07-2025,22:16:45| set snmp-s-operation-status = up succeeded
[20250723221647 1.2.3.9] (Jul 23 22:16:47 1.2.3.9) mw:: 1075| root| INTERNAL| 0.0.0.0| 23-07-2025,22:16:46| set snmp-s-operation-status = down succeeded
[20250723221647 1.2.3.9] (Jul 23 22:16:47 1.2.3.9) mw:: 1076| root| INTERNAL| 0.0.0.0| 23-07-2025,22:16:46| set snmp-s-operation-status = down succeeded
[20250723221647 1.2.3.9] (Jul 23 22:16:47 1.2.3.9) mw:: 1077| root| INTERNAL| 0.0.0.0| 23-07-2025,22:16:47| set snmp-s-operation-status = up succeeded
[20250723221719 1.2.3.5] (Jul 23 22:17:19 1.2.3.5) mw:: 482| 23-07-2025,22:17:19| WEB| 4.3.2.1| admin| SUCCESS: UPDATE remote-syslog-server-configuration-table[0] : remote-syslog-cfg-admin-status=enable
[20250723221740 1.2.3.5] (Jul 23 22:17:40 1.2.3.5) mw:: 1493| admin| WEB| 4.3.2.1| 23-07-2025,22:17:40| Deleted SNMP V3 user username = notusedtesting
[20250723221740 1.2.3.5] (Jul 23 22:17:40 1.2.3.5) mw:: 1494| admin| WEB| 4.3.2.1| 23-07-2025,22:17:40| delete table snmp-v3-authentication-table: succeeded
[20250723221741 1.2.3.5] (Jul 23 22:17:41 1.2.3.5) mw:: 483| 23-07-2025,22:17:40| WEB| 4.3.2.1| admin| SUCCESS: DELETE snmp-v3-authentication-table[1] : snmp-v3-authentication-username=notusedtesting | snmp-v3-authentication-password=******** | snmp-v3-authentication-security-mode=AuthPriv | snmp-v3-authentication-encryption-mode=DES | snmp-v3-authentication-auth-algorithm=MD5 | snmp-v3-authentication-access-mode=ROUser
[20250723221741 1.2.3.5] (Jul 23 22:17:41 1.2.3.5) mw:: 1495| root| INTERNAL| 0.0.0.0| 23-07-2025,22:17:40| set snmp-s-operation-status = up succeeded
[20250723221741 1.2.3.5] (Jul 23 22:17:41 1.2.3.5) mw:: 1496| root| INTERNAL| 0.0.0.0| 23-07-2025,22:17:40| set snmp-s-operation-status = up succeeded
[20250723221741 1.2.3.5] (Jul 23 22:17:41 1.2.3.5) mw:: 1497| root| INTERNAL| 0.0.0.0| 23-07-2025,22:17:40| set snmp-s-operation-status = down succeeded
[20250723221741 1.2.3.5] (Jul 23 22:17:41 1.2.3.5) mw:: 1498| root| INTERNAL| 0.0.0.0| 23-07-2025,22:17:41| set snmp-s-operation-status = down succeeded
[20250723221742 1.2.3.5] (Jul 23 22:17:42 1.2.3.5) mw:: 1499| root| INTERNAL| 0.0.0.0| 23-07-2025,22:17:41| set snmp-s-operation-status = up succeeded
[20250723221829 1.2.3.9] (Jul 23 22:18:29 1.2.3.9) mw:: 678| 23-07-2025,22:18:29| WEB| 4.3.2.1| admin| SUCCESS: SET sys-main-board-cold-reset-admin = on
[20250723221855 1.2.3.5] (Jul 23 22:18:55 1.2.3.5) mw:: 23-07-2025,22:18:55|98057|Remote communication failure||critical|raised|0|2|1|
[20250723221858 1.2.3.5] (Jul 23 22:18:58 1.2.3.5) mw:: 23-07-2025,22:18:58|98058|Radio loss of frame||critical|raised|0|2|1|
[20250723221858 1.2.3.5] (Jul 23 22:18:58 1.2.3.5) mw:: 23-07-2025,22:18:58|98059|Radio interface is down||warning|event|0|2|1|
[20250723221859 1.2.3.5] (Jul 23 22:18:59 1.2.3.5) mw:: 23-07-2025,22:18:59|98060|RFU RX level out of range||warning|raised|0|2|1|
[20250723222223 1.2.3.5] (Jul 23 22:22:23 1.2.3.5) mw:: 23-07-2025,22:22:23|98061|Radio interface is up||warning|event|0|2|1|
[20250723222235 1.2.3.5] (Jul 23 22:22:35 1.2.3.5) mw:: 23-07-2025,22:22:35|98062|Radio loss of frame||critical|cleared|0|2|1|
[20250723222235 1.2.3.5] (Jul 23 22:22:35 1.2.3.5) mw:: 23-07-2025,22:22:35|98063|RFU RX level out of range||warning|cleared|0|2|1|
[20250723222237 1.2.3.5] (Jul 23 22:22:37 1.2.3.5) mw:: 23-07-2025,22:22:37|98064|Radio loss of frame||critical|raised|0|2|1|
[20250723222237 1.2.3.5] (Jul 23 22:22:37 1.2.3.5) mw:: 23-07-2025,22:22:37|98065|Radio interface is down||warning|event|0|2|1|
[20250723222237 1.2.3.5] (Jul 23 22:22:37 1.2.3.5) mw:: 23-07-2025,22:22:37|98066|Radio interface is up||warning|event|0|2|1|
[20250723222240 1.2.3.5] (Jul 23 22:22:40 1.2.3.5) mw:: 23-07-2025,22:22:40|98067|Remote communication failure||critical|cleared|0|2|1|
[20250723222250 1.2.3.5] (Jul 23 22:22:50 1.2.3.5) mw:: 23-07-2025,22:22:50|98068|Radio loss of frame||critical|cleared|0|2|1|
[20250723222437 1.2.3.9] (Jul 23 22:24:37 1.2.3.9) mw:: 1078| root| INTERNAL| 0.0.0.0| 23-07-2025,22:20:34| set security-config-log-s-file-transfer-operation = none succeeded
[20250723222437 1.2.3.9] (Jul 23 22:24:37 1.2.3.9) mw:: 1079| root| INTERNAL| 0.0.0.0| 23-07-2025,22:20:35| set client-authorization-admin = 0 succeeded
[20250723222437 1.2.3.9] (Jul 23 22:24:37 1.2.3.9) mw:: 23-07-2025,22:20:53|129494|Unit has performed power up||warning|event|0|1|0|
[20250723222437 1.2.3.9] (Jul 23 22:24:37 1.2.3.9) mw:: 23-07-2025,22:22:23|129495|Radio interface is up||warning|event|0|2|1|
[20250723222437 1.2.3.9] (Jul 23 22:24:37 1.2.3.9) mw:: 23-07-2025,22:22:25|129496|Remote communication failure||critical|raised|0|2|1|
[20250723222437 1.2.3.9] (Jul 23 22:24:37 1.2.3.9) mw:: 23-07-2025,22:22:37|129497|Change in system reference clock quality level; new quality: g.813||major|event|0|0|0|
[20250723222437 1.2.3.9] (Jul 23 22:24:37 1.2.3.9) mw:: 23-07-2025,22:22:40|129498|Remote communication failure||critical|cleared|0|2|1|
[20250723222437 1.2.3.9] (Jul 23 22:24:37 1.2.3.9) mw:: 23-07-2025,22:22:44|129499|Loss of Carrier||major|raised|0|1|1|
[20250723222437 1.2.3.9] (Jul 23 22:24:37 1.2.3.9) mw:: 23-07-2025,22:22:48|129500|Ethernet interface is up||warning|event|0|1|1|
[20250723222437 1.2.3.9] (Jul 23 22:24:37 1.2.3.9) mw:: 1080| unknown| WEB| 4.3.2.1| 23-07-2025,22:22:54| Inactivity timeout
[20250723222437 1.2.3.9] (Jul 23 22:24:37 1.2.3.9) mw:: 23-07-2025,22:23:00|129501|Loss of Carrier||major|cleared|0|1|1|
[20250723222437 1.2.3.9] (Jul 23 22:24:37 1.2.3.9) mw:: 23-07-2025,22:23:03|129502|NTP locked on server||indeterminate|event|0|1|0|
[20250723222437 1.2.3.9] (Jul 23 22:24:37 1.2.3.9) mw:: 1081| root| INTERNAL| 0.0.0.0| 23-07-2025,22:23:37| set snmp-s-operation-status = down succeeded
[20250723222437 1.2.3.9] (Jul 23 22:24:37 1.2.3.9) mw:: 1082| root| INTERNAL| 0.0.0.0| 23-07-2025,22:23:38| set snmp-s-operation-status = down succeeded
[20250723222437 1.2.3.9] (Jul 23 22:24:37 1.2.3.9) mw:: 1083| root| INTERNAL| 0.0.0.0| 23-07-2025,22:23:39| set snmp-s-operation-status = down succeeded
[20250723222437 1.2.3.9] (Jul 23 22:24:37 1.2.3.9) mw:: 1084| root| INTERNAL| 0.0.0.0| 23-07-2025,22:23:39| set snmp-s-operation-status = up succeeded
Thank you, Eric. Very useful. Muchly appreciated!
