The R200 does not accept pulse dialing with the default configuration.
Is it capable of pulse dialing, and if so, what configuration change is necessary to activate it?
Thank you - Chris
Thank you - Chris
HI Chris,
Pulse dialing is not supported in cnPilot-R200 .
Chris,
I am curious. Are you really trying to use a rotary phone that only supports pulse dialling? Or am I missing something?
@Rajesh_V wrote:Are you really trying to use a rotary phone that only supports pulse dialling?
So far, about 1/4 of my customers have rotary phones [that only support pulse dialing] connected into their existing phone system.
The Grandstream HT502 supports pulse dialing. So, I can continue to use that unit for customers who want to keep their old phones.
