In the R-200, is there anyway that we can see the thoughput that the customer is downloading and uploading through the router?
Yes. So, assuming you have everything set up correctly and you are looking at the dashboard view in Cn Maestro. (from the home screen click monitor)
1.click on your network you set up. (should be under default in left hand column)
2. this opens a new list of devices under your tower set up, click any r200 device.
3. this should take you to dashboard view of that device, just scroll down to the third section. the graph on the left is labeled throughput. Cant miss it.
Hope thats what you're looking for!
