We find the EZ UI in the R195 routers to be far too limited. And when disabling EZ UI, the Basic User is able to change the WAN settings. We would like the EZ UI to have more settings available that will not affect service - ie. LAN subnet, DHCP, port forwarding, etc. When disabling the EZ UI, the Basic User is able to change WAN settings, which makes no sense at all - so it has nothing to do with the user level and everything to do with the EZ UI being on or off.
Or, better yet, give us the ability to select which options are available under the EZ UI.
