Any idea when this is getting fixed? Getting calls about it.
Hi Ryan,
Looking to roll it out in 2 weeks as a part of 4.4 release.
thanks
ashutosh
Ryan, if it remains a problem, I have a work-around that I've been using that may help.
Hey Uber. 4.4 installed and it still doesn’t work.
What is your workaround?
In your configuration, set:
swFastnatEnabled=0
You can make a file with just that line and push it to the router.
Or, you may be able to just set the router to defaults and test it.
Details:
I identified this "work-around" the end of last year and the R20x routers always set swFastnatEnabled=1 by default. They fixed the problem in some beta firmware. The latest firmware, however, no longer sets swFastnatEnabled=1 by default! I still don't have a clear answer for what the option does or what the preferred setting is.
Anyhow, on R4.4-R6 Verizon WiFi calling now works with swFastnatEnabled=1 or 0. You could probably test the configuration line above to see if it works... and if it does, try defaulting the router and see if it works at defaults. I suspect your issue is that swFastnatEnabled=1 is your current setting since it was part of the previous defaults, and for some reason it's not working with swFastnatEnabled=1.
I'm interested to know what you find.
