Hello guys, i hace setted up a r201p for a client with VoIP comming on a L2 vlan.
If i connect the grandstream IP phone directly with vlan tagged in the phone it works ok, if i put a Mikrotik in between the phone and the ePMP link with data and Voice vlan tagged in the MKT it works ok.
But When I configure the r201p with 3 data porta and one port to work (4) as a bridge for Voice with the voice vlan the phone registers ok with the PBX, and i am able to place and receive calls but with no audio in one way, specifically comming in.
I have enable and dissable “sip ALG” on the cnPilot device and in the MKT involved and i got the dame results.
The Issue has to be on the r201p since if I remove it from the equation it works ok.
Any suggestions will be very well appreciated.
Thanks.
