Radio calibration in 5.2 SMs
Dear all,
Some of the 5.2GHz SMs are showing the message as “Power level not calibrated”. Is there any way to calibrate the SM?
Any help will be appreciated.
Thanks and regards,
Punit
Hello,
try to upgrade to the firmware 8.2.7.
Maico
punit wrote:
Dear all,
Some of the 5.2GHz SMs are showing the message as "Power level not calibrated". Is there any way to calibrate the SM?
Thanks and regards,
Punit
Couple things:
(1) Are they running v8 of the Canopy software?
(2) Are they P10 Lite units?
(3) Were they using NAT and DHCP server?
If you answered yes to all three than these units have lost their calibration settings due to a bug in software releases prior to 8.2.7. You will need to contact your reseller to RMA the units for repair.
If you are running v7.x.x software on the unit you should be able to calibrate it.
Once you receive the email with the calibration info you can log in to the Canopy unit using the mgmt. ip and adding /mac.html
Thank you everybody for those amazingly helpful replies.
It fulfilled all my needs. I really appreciate it.
Punit :slight_smile:
You can calibrate your radios running 8.x.x software by inserting default plug and “radio calibration” tab will appear.
You just need to save settings and reboot.
Thats all
